lewavesi
Sep 29, 2021Tutor
RAX200 Router resets at a specific time (midnight)
NightHawk RAX200/Firmware: V1.0.5.132_1.0.69 Hi there, For the past few months I've had an issue with my Nighthawk router resetting itself at exactly the same time each night (midnight), and ...
- Oct 03, 2021
Pleased to report that router has been up for over 24 hours, and so disabling send log by email solved my issue.
I can leave the issue around why accessing the logs triggered the router to reset, for another day.
Sep 29, 2021Guru - Experienced User
When did it start happening?
Is this new or has it been going on since you got it?
What gateway is it connected to?
Are you sure its rebooting and not just renewing the IP from the modem/gateway?
- lewavesiSep 30, 2021Tutor
It has been happening for a couple of months, it's not too inconvenient because of the time it resets.
I will try and reset router to factory config and setup again.
- plemansSep 30, 2021Guru - Experienced User
You can try downgrading the firmware a version. Maybe its the version you're on.
- lewavesiOct 02, 2021Tutor
I think I may have traced down my issue.
I noticed another instance where the Router resets (or resets internet connection) - and this is where I try and access the logs (Advanced > Administration > Logs
When router resets and starts back up again - I can access the logs, but they have all been cleared.
I noticed that I had also previously setup Email alerts turned on (Advanced > Security > Email) and i had configured to send at ...... you guessed it... midnight.
So there must be an issue with accessing logs (maybe logs are getting too full .. inaccessible) and errors out when trying to access.
I've turned off email alerts - so hopefully this will stop those midnight resets.
