lewavesi
Sep 29, 2021Tutor
RAX200 Router resets at a specific time (midnight)
NightHawk RAX200/Firmware: V1.0.5.132_1.0.69 Hi there, For the past few months I've had an issue with my Nighthawk router resetting itself at exactly the same time each night (midnight), and ...
- Oct 03, 2021
Pleased to report that router has been up for over 24 hours, and so disabling send log by email solved my issue.
I can leave the issue around why accessing the logs triggered the router to reset, for another day.
lewavesi
Sep 30, 2021Tutor
It has been happening for a couple of months, it's not too inconvenient because of the time it resets.
I will try and reset router to factory config and setup again.
Sep 30, 2021Guru - Experienced User
You can try downgrading the firmware a version. Maybe its the version you're on.
