ankit49
Nov 11, 2019Aspirant
RAX200 Router Turns off by itself
Hi, I just bought the RAX200 with much excitement to make best use of my gigabit internet connection. Without even discussing about no better speed than my X6S router, I am most dissapointed ...
ankit49
Could it also be overheating?? Its not too hot but seems the router gets hot and the fan doesnt work all the time.
Nov 11, 2019Guru - Experienced User
If its randomly dying and you're still in your return/exchange window, I'd exchange it. I've got an RAX200 and its never powered down on its own.
When it happens what are the led's doing? Do they shut off? If they do, that's not a good sign. Again, return/echange it. If you're not in that period, it should have a 1-2 year warranty depending on your region. Start a support case.
- ankit49Nov 11, 2019Aspirant
Hi,
Thanks for your response.
The LED's turn off, its dead until I restart it.
I believe it is an overheating issue. Getting a replacement is not easy as I have bought it from Amazon Global shipment to India. Spent USD 1000 for a product that isnt even ready for the market yet? Netgear has definitely dissapointed!
I am trying to downgrade the firmware to see if the fan works better this way as I hardly feel it working on the latest firmware.
