scottunlv's avatar
Mar 28, 2021
Rax200 Tri Band issues - I lose 1 of my 5hz channels
I am noticing I keep losing signal to of of my tri bands. My network will keep the 2.4, but I lose the first 5 but the second 5 stays up. the only way I can get it back it restarting my router and it has happened for a while now.
I do have an EX8000 extender, the naming has the EXT at the end., that keeps going down also.
  • I had similar experience for a long time and found no real help online but whatever magic combo I did last has led to stable and fast speeds. I could not isolate what actions did this so I cannot be much help. I can share my current configuration but remove my personal data. Let me see how.
  • I am in the same boat. The higher 5ghz band is causing interference with my tv sound system and I change the channel on it which causes me to lose the lower 5 ghz bands internet connectivity and also the higher band loses about half the channels you can select from and gets stuck in channel 100 no matter which one you choose.
