Jluttichau
Jul 06, 2020Guide
RAX200 Unresponsive
I have this issue with my Nighthawk and it has occured a few times now. What i see is that there is a strong wifi signal as usual. But when i try to log onto the wifi it says the WIFI password is w...
RajaDaja
Jul 14, 2020Luminary
I had those same issues. Chalk it up to flaky firmware......BTW. what firmware are you on? I'm on 1.0.2.8_1.0.45 which I found to be the most stable for me.
Jluttichau wrote:I have this issue with my Nighthawk and it has occured a few times now.
What i see is that there is a strong wifi signal as usual. But when i try to log onto the wifi it says the WIFI password is wrong (but it's not). All the lights are on the router, however the internet icon is amber as if the internet connection is down (it's not). There is no response when i use the night hawk app to connect remotely.
When i use a wired connection from my PC it will not give me an IP adress from the DHCP.
When i powercycle the router it goes back to normal. But there is nothing useful in the logs to help me find the root of the problem.
Anyone else having this issue and found the cause of the crash, or is it just a bug in the router?
