Jluttichau
Jul 06, 2020Guide
RAX200 Unresponsive
I have this issue with my Nighthawk and it has occured a few times now. What i see is that there is a strong wifi signal as usual. But when i try to log onto the wifi it says the WIFI password is w...
Jluttichau
Aug 11, 2020Guide
So this morning it occured again, it's says the password is incorrect.
A small twist this morning as I am also unable to log into the nighthawk app so i can't get too see if the router is behaving like the last time.
It's been around a month now since it happened last, there have been no issues in this period, but now it doesn't work. This is extremely frustrating and time consuming for a product that should be top of the line. I am seriously considering chaging over to some other brand.
I am always running the latest firmware, and i don't see downgrading to a former version as a viable solution as this will remove any security patches that have been released.
michaelkenward
Aug 12, 2020Guru - Experienced User
And your modem, if there is one, is?
- JluttichauAug 19, 2020Guide
I don't understand your question, could you elaborate?
So recent update, i had the same problem two days in a row.
I now have a very cheap nighthawk for sale, comes with endless amounts of headaches.
- JluttichauAug 21, 2020Guide
So the problem intensifies, the only change has been the upgrade to the new firmware a few weeks ago and now the problem has occoured every morning. There was a twist in the problem today, the router began working some time in the day but now it says the password is incorrect again.
