Jluttichau
Jul 06, 2020Guide
RAX200 Unresponsive
I have this issue with my Nighthawk and it has occured a few times now. What i see is that there is a strong wifi signal as usual. But when i try to log onto the wifi it says the WIFI password is w...
PistolPeteMia
Aug 17, 2021Tutor
I had a similar problem, in my case the WiFi was slowing down to the point powercycling the router was a temprary fix (I thought it was firmware at this point). Keep in mind, at no time were my wired connections affected. Upon cycling the power the first time I noticed the surface being hot but didn't think much of it... Fast forward a couple weeks, the powercycling was not making a change in performance and now I was seeing intermittent dropping. When I attempted to login to the router over the 2.4 or 5.0 - 2 of 5 attempts were successful but the homepage to the router UI was slow in rendering. The 3 other attempts the connection would fail all together either as Connection_Err or device cannot_be_found. Fast forward to today, WiFi is completely down, non-responsive and Support is in a daze... I've restored from factory twice and waiting for an RMA. I'll update this post as new information comes
