javrueda
Aug 04, 2020Initiate
RAX200 V1.0.2.98_1.0.54 issues
I installed the new firmware yesterday and it has disconnected from the internet 4 times in the last 24 hours. Every time it happens I have to reboot the router manually, this is a bad firmware, be ca...
- Aug 05, 2020
I decided to factory reset the router yesterday night and since then there has not been any issues so far. If anyone has the same issue save your settings first, then factory reset and restablish your settings, it worked for me. Or you can follow LOL2kde solution to revert back to the previous firmware.
LOL2kde
Aug 04, 2020Aspirant
I also have problems with this firmware, and after a while the 2.4 and the 5_1 GHz band completely disappears. then only the 5_2 ghz band is still there.
after a reset, it goes again for about 1-3 hours. with the previous firmware ... 88 I put it back on, the problems are gone. So the problem can only be the firmware ... 98!
