javrueda's avatar
javrueda
Initiate
Aug 04, 2020
RAX200 V1.0.2.98_1.0.54 issues
I installed the new firmware yesterday and it has disconnected from the internet 4 times in the last 24 hours. Every time it happens I have to reboot the router manually, this is a bad firmware, be ca...
  • javrueda's avatar
    Aug 05, 2020
    I decided to factory reset the router yesterday night and since then there has not been any issues so far. If anyone has the same issue save your settings first, then factory reset and restablish your settings, it worked for me. Or you can follow LOL2kde solution to revert back to the previous firmware.
