javrueda
Aug 04, 2020Initiate
RAX200 V1.0.2.98_1.0.54 issues
I installed the new firmware yesterday and it has disconnected from the internet 4 times in the last 24 hours. Every time it happens I have to reboot the router manually, this is a bad firmware, be ca...
- Aug 05, 2020
I decided to factory reset the router yesterday night and since then there has not been any issues so far. If anyone has the same issue save your settings first, then factory reset and restablish your settings, it worked for me. Or you can follow LOL2kde solution to revert back to the previous firmware.
javrueda
Aug 05, 2020Initiate
- LOL2kdeAug 06, 2020Aspirant
do you use:
WPA2
orWPA2 + WPA3 ?
- LD100Aug 06, 2020Guide
Good question--WPA2 + WPA3 on 802.11ax using all three bands. QoS and guest network are not enabled.
All other wireless features are enabled.
Although my HP Envy 120 printer/scanner is not happy with that and in order to connect it to wifi, I have to change to WPA2.
Always connects to my Killer Wi-Fi6 adapter in desktop on 5GHz low and my smart home thermostat on 2.4 GHz (which has no
problems with WPA3). Laptop goes to whatever band is least congested.
Still running with V1.0.2.98 and no problems.
Hope this helps!
