javrueda
Aug 04, 2020Initiate
RAX200 V1.0.2.98_1.0.54 issues
I installed the new firmware yesterday and it has disconnected from the internet 4 times in the last 24 hours. Every time it happens I have to reboot the router manually, this is a bad firmware, be ca...
- Aug 05, 2020
I decided to factory reset the router yesterday night and since then there has not been any issues so far. If anyone has the same issue save your settings first, then factory reset and restablish your settings, it worked for me. Or you can follow LOL2kde solution to revert back to the previous firmware.
Kris82
Aug 09, 2020Star
This morning I noticed that the date on the router ((Nighthawk RAX200) was 2 days off (Saturday, not Monday), though the time was correct. I upgraded the firmware to 1.0.2.98_1.0.54 this weekend and suspect that's the cause, especially since I never saw this problem on the router before the update. I rebooted the router, which fixed the date. I will keep watching in case it goes awry again.
- Kris82Aug 10, 2020Star
I noticed that the time the router shows is wrong too - it shows the time of the last reboot. When I rebooted the router again, the time that displayed was correct, but I expect it and the date to be wrong again as time passes.
