wingdam's avatar
Aug 05, 2021
RAX200-V1.0.5.126_1.0.65 bad zip
I've downloaded this 3 times and win zip, 7zip and winrar all report a bad zip file.
  • Re downloaded today and everything unzipped. Old downloads still bad.
    It must have been something with the ISP.
  • > I've downloaded this 3 times and win zip, 7zip and winrar all report a
    > bad zip file.
       Worked for me.
          https://www.downloads.netgear.com/files/GDC/RAX200/RAX200-V1.0.5.126_1.0.65.zip
    $ ls -l RAX200-V1.0.5.126_1.0.65.zip
    -rw-r--r--@ 1 sms  staff  77595565 Aug  5 20:36 RAX200-V1.0.5.126_1.0.65.zip
    $ unzip -t RAX200-V1.0.5.126_1.0.65.zip
    Archive:  RAX200-V1.0.5.126_1.0.65.zip
        testing: RAX200-V1.0.5.126_1.0.65.chk   OK
        testing: RAX200-V1.0.5.126_1.0.65_Release_Notes.html   OK
    No errors detected in compressed data of RAX200-V1.0.5.126_1.0.65.zip.
       What are the name and size of your "a bad zip file"?
  • Win rar
    ! D:\Downloads\RAX200-V1.0.5.126_1.0.65.zip: The archive is corrupt
    • plemans's avatar
      have you tried the built in windows one or 7zip?
    • wingdam's avatar
      wingdam
      Star
      • antinode's avatar
        antinode
        Guru
           Or anything else which touched the data.
           And now we can see why zip archives include basic checksums, allowing
        a simple data-integrity check.  And one reason that organizations like
        Netgear distribute such files in such archives.  (Clearly, the slight
        compression was, by itself, not worth the bother.)
