Porthgwidden
Aug 21, 2020Follower
RAX200 very slow
I've had my router about a month and I'm having serious WiFi speed problems. Its internet connection is 70, which is good for my area, but WiFi speed varies between 0 and 30. I'd like to change channel but, stupidly, I don't remember even changing the login and password but I must have done because I can't get in. Is there anything I can do? Thank you.
1 Reply
This is how to recover the password.
If you don't remember your login or your security questions to recover the login (or didn't set them up), then you'd need to factory reset to get back to the defaults.
