Teamcraig
Oct 05, 2020Aspirant
RAX200 vs XR1000
I am in the market for a new router ... currently have a Nighthawk X4 AC2350/R7500 router. I am trying to decide between the RAX200 and the XR1000. I live in a moderetly sized ranch style house where the router is located in the basement. Due to the pandemic, there are 4 people at home working and attending virtual school. The house was built with network outlets in every room. So we have several devices connected to the router directly (3 Xbox Ones) and several (smart TV's) connected through a splitter (Netgear 8 port splitter). The remaining devices (phones, laptops, etc) are connected via the wifi.
Yes, we like to game ... but it seems the RAX200 would be the better solution for connectivity and speed. The DumaOS software seems to be the only advantage for the XR1000.
Thoughts? Suggestions?
Thank you.
The R7500 is a fairly solid router.
And from the sounds of it, you have most of your gaming setup and tv's hardwired in. Thats optimal for taking a load of the wireless. You've kind of got the ideal.
How big is the home? moderate means different things to people.
Reason I ask is if have you checked into using a mesh system and placing them around your home? You'd get better wireless coverage which seems to be what you're looking for since you seem to have the high bandwidth devices already optimized.
Wireless broadcast distance didn't change a while lot with the move from wireless AC to wireless AX. so if you're looking for coverage, then I'd look at a mesh setup. If you're looking for just jumping to AX, then I'd look between the two you picked.
If you're looking for some optimized ping/lag times, I'd look at the XR1000.
If you're looking for the triband to seperate out some devices, then I'd look at the RAX200.
If you're looking for additional coverage, then I'd look for a mesh setup .
Personally, I've got the RAX200 and went back to a mesh setup because of the added range with mesh.
- TeamcraigAspirant
Thank you Plemans for the information and quick response! To answer your questions, the foot print of our house is 1800sq ft. Its a ranch style house so we have 3600 between the 2 floors ... most of which is finished sq footage. The current router is located in the basemane at one end of the house and we had issues connecting on the other end of the house. So, I forgot to mention we do have a AC2200 Nighthawk X4S extender that I have upstairs and in the middle of the house. This solved our connectivity/coverage issues when on the other side of the house.
We have 1GB internet service and but still seem to have some lag or temporary interuptions (rare, but it happens) ... I assume due to the heavy use right now. I expect it to get worse as winter comes and we will be inside even more. I was thinking that a newer faster router (and/or switch ... our switch is the Netgear GS60 8 port) could solve this issue. Or I guess, I would hope it would.
3600sq ft is what I'd consider on the large size because its spread out on 2 floors.
do you have your extender hardwired in running in AP mode? or is it running in extender mode?
Is it certain devices that tend to have issues? or certain bands? (2.4ghz vs 5ghz)
Do the devices that are hardwired running fine?
with your 1 gig service, is it cable or fibre? Cable tends to have much lower upload speeds (usually around 30-50mbps)
Switches are pretty much set and forget. They ether work or they don't. I've never had one gradually go bad. Not saying it can't happen but their fairly reliable.
