YoungSpicket
Oct 09, 2019Star
RAX200 WAN Aggregation auto QOS bug
On current and shipping firmware, RAX200 will cut wired and wireless internet speeds in HALF when WAN aggregation is active. This appears to be a bug with WAN aggregation implementation during channel...
YoungSpicket
Oct 09, 2019Star
Thanks Christian. Also, I noticed that there seems to be WPA2 authentication issues after changing wifi settings (at least on the 5ghz band), sometimes it won't except the saved wifi password until another reboot of the router.
As an aside, besides naming both 5ghz bands the same name, is there a way for the router to smartly balance between the 5 ghz bands WITHOUT the 2.4 band ala the Asus AX11000, which i believe shares a chipset with the AX12 triband.
Christian_R
Oct 10, 2019NETGEAR Employee Retired
Hi YoungSpicket,
I have sent you a message with further questions for further isolation.
Christian
- YoungSpicketOct 10, 2019Star
I answered your questions. My current config file doesn't have WAN aggregation enabled and I am not turning it on again as it will require me to reset all my settings to fix it afterwards. I use my router for business purposes and can't afford to keep doing that.
- KonkhraNov 06, 2019Tutor
Has this been addressed yet? I just set this up with a RAX200 and CM1150v but seems speeds are way off.
- Christian_RNov 07, 2019NETGEAR Employee Retired
Hi Konkhra,
I'd like for our support team to reach out to you for assistance. If you're interested, please send me a message with your contact info and serial number.
Thanks,Christian
