Randy_Wu
May 15, 2020Aspirant
RAX200 Wan Aggregation
Hi I am looking to purchase an RAX200. If my modem has a 1Gbps coming out from port 1 and port 3, am i able to set the Wan aggregation?
May 15, 2020Guru - Experienced User
Randy_Wu wrote:Hi I am looking to purchase an RAX200.
The RAX200 supports wan aggregation. Does your modem? They both need to support link aggregation, not just the router.
what modem are you using?
Randy_Wu
May 18, 2020Aspirant
HI,
How do i know if the modem supports wan aggregation.
From what i tried i have a PC which has 2 lan ports and i do a link aggregation on the PC i am getting around 1.5Gbps.
I am assuming if I plug the 2 lan ports into the RAX200 i should be getting the same kind of performance when doing the wan aggreagation.
- plemansMay 18, 2020Guru - Experienced UserWhat modem is it?
- plemansMay 19, 2020Guru - Experienced User
I still couldn't find if that device supports link aggregation properly.
but I did find that its an integrated ont/router device.
Which could cause issues if you're using that and the RAX in router mode.
but you could potentially put the huawei device in passthrough mode or the netgear in access point mode
