DrPhoggy
Jun 04, 2022Tutor
RAX200 Websites not loading
I’m using the RAX 200, which has worked beautifully to this point, but I’ve recently had a problem where certain websites are not loading when connected to my home Wi-Fi network. The same websites loa...
Jun 04, 2022Guru - Experienced User
what modem/gateway do you have?
What firmware is on the router?
Do you have IPv6 enabled?
have you tried a different dns server for both ipv4 and ipv6?
- DrPhoggyJun 04, 2022TutorWe have the standard Google Fiber modem, and the current firmware for the router V1.0.6.138. I don’t know about IPv6. I don’t see a setting for that specifically on the Nighthawk app, so I apologize for my uncertainty about that.
- plemansJun 04, 2022Guru - Experienced User
what standard google modem is it?
try enabling ipv6. Its done through the browser and not the app.
How do I set up an IPv6 Internet connection on my Nighthawk router? | Answer | NETGEAR Support
- DrPhoggyJun 04, 2022TutorI’ll have to do some searching on the modem specifics. Sorry about that! It was updated by Google Fiber 18 months ago .
I’ve tried IPv6, and that seems to be improving things already. Thank you! I will continue to monitor it. I wasn’t sure about the settings, so I chose Auto Detect.
