FranciscoMx
Aug 20, 2021Tutor
RAX200 Wifi disconnects once a week
I am very disappointed with this expensive router. I thought I was buying state of the art, the batman of the home routers wenn I bought the RAX200 Nighthawk router, but it keeps disconnecting the wi...
Aug 21, 2021Guru - Experienced User
How long have you had it?
What modem/gateway do you have?
What it starts having issues (after that week period) what exactly happens? Do devices say "connected, no internet", does wifi stop broadcasting, what actually happens?
Did it ever work properly? If so, when did it change?
FranciscoMx
Aug 23, 2021Tutor
Thank you, Plemans for your answer. I have it since end of November 2020 and because I bought it in Switzerland ( activated in Brazil where I am based now) I have a 2 years waranty until 4 of December 2022.
I use a PPPoE connection that the router controls. I just inserter my username and password i the routers PPPoE tab. There is no other hardware.
The wifi stays on in my Macbook pro and Iphone 12, my alexa echo dots say "the internet is down or the like" however the app does not connect to the router.
I have used the router at my present location in Brazil since December 2020. I only became acutely aware of this "internet blocking"/ router not working in March 2021. I also read other similar experiences online. Somebody told me to do a factory reset which I have never done. Firmware is up to date. I cant have a router that disconnects everyweek. I have security cameras that rely on a trustworthy router to keep working nonstop. Netgear customer service is nonexistant.
- plemansAug 23, 2021Guru - Experienced User
It might be the ip lease from your ISP expiring and not auto-renewing.
You could try the factory reset or downgrading the firmware.
Doesn't hurt to try.
