JJ24
Apr 12, 2022Initiate
RAX200-Wifi SLOWING DOWN and dropping
Wifi 2.4 SLOWING DOWN and disconnecting me at times. 5G doesn't even wanna connect most of the time. I've rest the router so many times and a master resets. Nothing is working even thought it was my ...
Apr 12, 2022Guru - Experienced User
1. what actual firmware version are you on?
2. what modem/gateway is it connected to?
3. do wired devices have issues or just wireless?
4. is it both bands for 5ghz or just one of them?
5. are you using smart connect?
JJ24
1. Firmware - V1.0.5.132_1.0.69
2. Modem - ARRIS surfboard SB8200
3. No wired are 100% good
4. Just 1 5g turned off 2nd one
5. No smart connect
Thanks for the reply 😁
