Synomenon
Apr 27, 2020Star
RAX200 "Wings" don't click or snap into place?
Do the RAX200's "wings" really not snap or click into place? They seem to just sit there, unsecured. I followed the graphic on the stickers found on the wings.
psychopomp123
Apr 28, 2020Luminary
Hi,
The wings of the RAX200 do clip into place - once you flip them open into the vertical position then you push them down slightly until you hear a gentle click. To fold them, you reverse the process. But they do seem a bit flimsy, because even when they're in the locked position they still move about slightly.
Cheers
- SynomenonApr 28, 2020Star
I don't hear any "click" when I place them in vertical position then push them down. There's no resistance or reassurance at all that they'll stay there.
- psychopomp123Apr 28, 2020Luminary
In that case you might have a faulty unit. I suggest asking Netgear if they can send you a replacement under warranty.
