NowWatt
Jan 07, 2020Initiate
RAX200 WPA3 availabilty?
The RAX200 is suppose to be a high end / all encompassing router that will brush your teeth if wireless toothbrush is compatible.
Who spends $500 on a rocket that doesn't have WPA3? I won't. Cmon Netgear, your lower / less expensive routers have WPA3 - communicate with us when available.
- avtellaProdigy
WPA3 is probably not stable on the Broadcom chipset yet, I know Asus also only had betas with WPA3 for basically the same hardware ie the GT-AX11000 last time I checked.
As for the less expensive model having WPA3:
The RAX120 actually is the superior model chipset wise and Qualcomm usually does a better job of implementing features in its chipsets.
The RAX200 is pretty much just an RAX80 (effectively the same CPU & chipset as the RAX200) with an extra 5Ghz radio and a 2.5Gb Eth port slapped on for which you pay the premium over the RAX80.
- psychopomp123Luminary
The extra 5ghz radio on the RAX200 makes it superior to the RAX120. Hence why the RAX200 costs more. Sure, not everybody needs/wants an extra 5ghz band but for those that have tons of wifi clients (like me), then a tri-band router like the RAX200 is a great choice. No issues at all with my RAX200, love it to bits. And no, i didn't pay $500+ for it either :)
I should also add, its becoming a bit of an outdated myth that Qualcomm chipsets are still vastly superior to Broadcom units. Sure, that may have been the case when features like Mu-Mimo were first released a few years ago but Broadcom chipsets have finally caught up in the last year or two. As an example. my RAX200 performs just as well as my R9000 (QCA based), if not better.
