Eric35
Apr 28, 2022Guide
Rax200 WPS?
Hi. Is there a easy way to disable wps on nighthawk ax12 ?
Eric35
May 01, 2022Guide
Bump.
Plz help?
Plz help?
- DarrenMMay 02, 2022Sr. NETGEAR Moderator
No the Rax200 does not have settings to fully turn off WPS.
- Eric35May 02, 2022GuideWell that's too bad isn't it?
What if someone find a bug hole through the WpS and can hack rax200?- DarrenMMay 04, 2022Sr. NETGEAR Moderator
You can report any security issues with routers here so it will be escalated to engineering to patch it as quick as possible https://www.netgear.com/about/security/
