Ufm-uk
Dec 26, 2022Aspirant
Rax200 wrong password
Recently my rax200 seems to be kickijg Everything off and preventing access via Wi-Fi with a “incorrect password” message. When the password has not been changed.
Ufm-uk
>>> Are you sure the Ethernet cable between the RAX200 and the upstream device is good? Cat 6 cable is recommended.
Yes that’s all good
>>> What is version number of the firmware installed on your RAX200? The "latest" is not an answer. A version number is required to confirm your answer.
Firmware Version
V1.0.10.140_1.0.79
Yes that’s all good
Firmware Version
V1.0.10.140_1.0.79
Kitsap
Dec 26, 2022Master
Yes that’s all good
Firmware Version
V1.0.10.140_1.0.79
Repeat questions from a previous post. Ignoring them will not make them go away....
What is the brand name and model number of the upstream modem/gateway/ONT (optical network terminal)?
How long has it been since you powered down (pulled the power cord) and let the router set for a couple of minutes before restarting?
- Ufm-ukDec 26, 2022AspirantWhat is the brand name and model number of the upstream modem/gateway/ONT (optical network terminal)?
>>> don’t see how that is relevant because the problem is happening on the internal network, but the modem connected is the ZTE three MC801A which has been working with the RAX200 for the last 6 months without issue.
>>> Yesterday I did this- KitsapDec 26, 2022Master
>>> Yesterday I did thisYour ZTE three MC801A is a combination cell modem/Wi-Fi router device. It can have a significant impact on the use, access, and operation of other devices connected downstream on your LAN. Is your cell modem hub configured in bridge mode? If not, you need to review the configuration instructions where it explains how to configure the device to connect a Wi-Fi router downstream.
Read about a double NAT situation on your LAN here: https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad
Just because a device has been working for the last 6 months with out issue does not mean a great deal. There could have been firmware updates on your cell modem gateway or on your router just prior to your issues starting.
- michaelkenwardDec 27, 2022Guru - Experienced User
>>> don’t see how that is relevant because the problem is happening on the internal network, but the modem connected is the ZTE three MC801A which has been working with the RAX200 for the last 6 months without issue.Perhaps because, unlike Kitsap, you haven't dealt with enough problems here to realise that this can be the most important question when problem solving. It isn't thrown in just for fun.
What is Double NAT? | Answer | NETGEAR Supportand
How to fix issues with Double NAT | Answer | NETGEAR Support
- Ufm-ukDec 27, 2022AspirantOk the modem is now in bridge mode, but part of the problem still exists in that I get a freeze and no not work access Randomly throughout the day? Probably a different problem. I’ve checked for overheating and that isn’t an issue.
