jcv2428
Sep 19, 2019Aspirant
RAX200
My new RAX200 router is not capable of maintaining 400Mbps speed from my internet service provider. I spent 2.5 hours on the phone, screen sharing with a Netgear technician today trying to find out ...
thinksinc
Oct 02, 2019Apprentice
I also just received and set up my RAX200 today, and am not getting expected WiFi 6 speeds on my (only) WiFi 6 capable devices: an iPhone 11 Pro Max and an Intel WiFi 6 card in my Dell XPS 15.
I was previously using a Netgear Nighthawk R8500 for WiFi. I have gigabit internet service from Xfinity. On Ethernet, I average about 950+ Mbps. On WiFi, I averaged around 350-380 Mbps on most capable devices.
I did a simple swap-out, replacing the R8500 with the RAX200 (plugged into the same switch port on a Nighthawk S800). I used the same SSIDs so most of my devices will reconnect without issue.
After connecting the RAX200, my WiFi speeds are the same (at best) and a little slower at times than the R8500 using the iPhone 11 and WiFi 6 card on my Dell XPS. I've restarted my modem (a Netgear CM1000), the router, the devices I'm connecting with, etc.
In the RAX200 setup, I'm using WAN Preference: Internet Port (1Gbps). Not sure if I'd see any improvement selecting either of the Multi-Gig options here, since my Xfinity service is 1Gbps.
In the RAX200 Setup > QoS Setup, the built-in Speedtest reports Download speed of 937Mbps, so it's seeing that speed from my modem, it's just not delivering anything close to that speed to my WiFi 6 devices.
I left most of the other RAX200 settings at default. Is there anything simple I'm overlooking for not getting virtually any WiFi speed increase on devices supporting WiFi 6?
Oct 02, 2019Guru - Experienced User
thinksinc wrote:I also just received and set up my RAX200 today, and am not getting expected WiFi 6 speeds on my (only) WiFi 6 capable devices: an iPhone 11 Pro Max and an Intel WiFi 6 card in my Dell XPS 15.
Please start your own thread for us to best assist you.
- mlotov83Oct 28, 2019Star
Were you able to find any solution? I have different thread started for same issues.
- mlotov83Nov 13, 2019Star
Any solutions on this thread?
- Christian_RNov 14, 2019NETGEAR Employee Retired
Hi mlotov83,
I believe you mentioned in another thread that you had a ticket open with our Support Team. Has Support followed up on your case since? If not, please send me a message with your case number as I'll be glad to look into it for you.
Christian
