Yousef
May 13, 2020Guide
RAX200
Hi, i do have RAX200 its really has an amazing performance, my question is i want connect an extender like a mesh orbi, i just i dont know which one is the best options for my house becase the ro...
- May 14, 2020
You can literally run it like the one in my signature.
modem-----RAX200------Orbi-----orbi satellites.
Mine works great. I have the RAX for controlling everything as well as peak wireless speeds and then orbi for overall coverage. the orbi is setup in AP mode to prevent a double nat.
TerryPh
May 14, 2020Virtuoso
My house is 2 -story brick walled house. ( old Craftman built in the early 1900's) , about 2800 sq ft, and a separate garage structure with guest house about 100 feet away
So , my network finally work well as far as extending the WiFi signal throughout the house and the garage.
Modem -->RAX120--> RBS40V2 ( as an extender)
--> EX7300 as an extender for both 2.4g and 5g signals.
The network system works so well, particularly eliminating the deadpots in my house effectively.
Yousef
May 24, 2020Guide
the extender +mesh will works perfectly the problem i do have in my house is an old design and its tottaly not in on line link modern houses, that why i got stuck on how to mange it.
thanks alot
