Yousef
May 13, 2020Guide
RAX200
Hi, i do have RAX200 its really has an amazing performance, my question is i want connect an extender like a mesh orbi, i just i dont know which one is the best options for my house becase the ro...
- May 14, 2020
You can literally run it like the one in my signature.
modem-----RAX200------Orbi-----orbi satellites.
Mine works great. I have the RAX for controlling everything as well as peak wireless speeds and then orbi for overall coverage. the orbi is setup in AP mode to prevent a double nat.
lmanpunk
May 23, 2020Star
I would not recommend the RAX200. The wireless drops multiple times a day. The wifi completely disappears for a few minutes. There are also times when the performance is extremely slow. Overpriced paper weight. My r7000 is 100 times better. Netgear pushing out unproven hardware, making the consumer beta testers.
Yousef
May 23, 2020Guide
i got your points, but there is something you have to understand about the wireless dont keep it enable in smart mode as i got if your device not use to be compitable with smart mode it will keep disconnected 100 times per days becuase its not compitable to be stable in smart mode my devices is not stableable so i disable this mode and its now working perfectly stable and better than my olds router for sure, keep it up to date also.
- lmanpunkMay 23, 2020Star
I dont use smart mode. I would have hoped the RAX200 could have handled all my devices but it handles them worse than my R7000
- YousefMay 23, 2020Guide
its strange you are the first one saying that maybe u need to replac it with the warrenty sometimes its come faulty from the company before i used to replace it manytime maybe you have something wrong from the factory, because mine it working and handle the devices perfectly.
