sharkuae
Jan 03, 2021Follower
RAX200
Dear support team, I have two device RAX200 and both of then the lan connection stop working when i try to connect using lan cable and i can access the device using only wireless soultion and som...
Christian_R
Jan 07, 2021NETGEAR Employee Retired
Hello sharkuae,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
