aeperkins63
Aug 26, 2021Guide
RAX200
Trying to figure out which Orbi extenders will go well with my RAX200 router to give me the best extended, with signal strength that will work together with no issues/ Can anybody reccommend some Orbi extenders, I only need 2 for the size of my home, to get the job done. I appreciate all.
The RAX200 isn't an orbi router so the regular orbi satellites wouldn't work with it. The only 2 orbi satellites that would work are the RBS40V and the RBS50Y because they have an extender mode as well as their orbi mode. You could just use standard extenders and not the orbi ones.
Thank you sir
