Eric35
Dec 23, 2021Guide
Rax200
I really would want to change the Dhcp lease time, but i can't finf it anywhere in settings? Where can i find this?
Dec 23, 2021Guru - Experienced User
Why are you trying to change lease times?
A better explaination of what you're trying to accomplish and why might help more to figure out your issue.
- Eric35Dec 23, 2021GuideI want to change Lease time for Dhcp as i could in Amplifi Router.
Because i am testing something since i have 2 ISP at my house.
Do you know where exactly in settings or not ?- plemansDec 23, 2021Guru - Experienced User
Eric35 wrote:
Do you know where exactly in settings or not ?I always love when people are rude on a public support forums.
Its literally members of the public helping out for free because we want to help people.
And the benefit is, this isn't a job. I don't have to sit and smile and answer.
So I can choose to ignore your posts anymore. Good luck.
- Eric35Dec 23, 2021GuideAnyone that can help me ?
- FURRYe38Dec 23, 2021Guru - Experienced User
If you don't see DHCP Least times in the routers UI or mentioned in the user manual, then I presume the least time on NG routers are set for something specific, handle automatically and not user changeable.
