aeperkins63
Aug 22, 2023Guide
RAX200
Just wanted to ask when looking for updates on the screen for updates and reboot, do you recommend rebooting once a month or only when it may not be operating normally??
Aug 22, 2023Guru - Experienced User
When you encounter a problem, try a reboot first.
Routers are designed to be online all the time with out any reboots. if reboots are needed all the time, there maybe a problem that needs to be vetted that reboots are covering up.
