aeperkins63
Aug 22, 2023Guide
RAX200
Just wanted to ask when looking for updates on the screen for updates and reboot, do you recommend rebooting once a month or only when it may not be operating normally??
michaelkenward
Aug 23, 2023Guru - Experienced User
aeperkins63 wrote:
..... do you recommend rebooting once a month or only when it may not be operating normally??
Apart from firmware updates, when the router will reboot itself, the only time I reboot a router is when the mains power goes off and comes back on.
Other than that, leave it alone.
I'm the same. Leave it 24/7 unless the power dies or I have an issue with something.
