Desabells
May 09, 2023Aspirant
RAX29 — Nighthawk AX2400 WiFi 6 Router
I just purchased a Nighthawk AX2400 router. I connected a Seagate 4TB external hard drive to the USB connector. Everything works but the drive only shows 196 MB of free space. There is nothing on the...
Desabells
May 10, 2023Aspirant
I actually did a lot of research on getting rid of the 200 MB partition. You can't do it through Disk Management, you have to do it through Command Prompt. This is how I did it.
michaelkenward
May 10, 2023Guru - Experienced User
It depends on the partition.
I confess that that I have software that is designed to handle that sort of thing, both Acronis and EaseUS Partition Master.
Does this mean that you have fixed it?
- DesabellsMay 10, 2023Aspirant
I have been successful in reformatting the drive many times but so far I always end with the same result. If the 200 MB EFI System Partition is present then the router can access the drive but only that 200 MB partition. If that 200 MB partition isn't present any longer (because of reformatting and removing it) the drive is not even recognized.
I'll keep working with it and see if I can come up with something.
Again, I appreciate you offering suggestions.
