Janromero
Aug 15, 2023Aspirant
Rax29 AX2400
I have a Fios internet router as main and installed 3 Netgear wifi routers as AP.... AX2400, Rax10 and R7000. Both Rax10 & R7000 status says "Connected" but the AX2400 says "not connected" but it is w...
michaelkenward
Aug 16, 2023Guru - Experienced User
Janromero wrote:
....the AX2400 says "not connected" but it is working fine. Why is this?
AX2400 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
