Janromero
Aug 15, 2023Aspirant
Rax29 AX2400
I have a Fios internet router as main and installed 3 Netgear wifi routers as AP.... AX2400, Rax10 and R7000. Both Rax10 & R7000 status says "Connected" but the AX2400 says "not connected" but it is w...
Aug 16, 2023Guru - Experienced User
Do you actually have it set to access point mode?
Also, is it connected via its wan port?
- JanromeroAug 16, 2023AspirantYes, all was setup at the same time via netgear AP automatic install after factory reset. All are connected via wired (not on WAN port). My network is running fine but that "not connected" msg is ?????
- KitsapAug 16, 2023Master
The subject line of your original post indicates you have a RAX29 plus the other routers configured as APs.
I would suggest your power down your Fios router and the three APs (pull the power cord). Connect the Ethernet cords from your router to the WAN input port on each of your APs. Power up the router and then the APs one at a time and give them time to boot. Then check the connection status on each of your APs.
- JanromeroAug 17, 2023AspirantI will try that and get back to you.
