Taddeusz2002
Dec 14, 2022Aspirant
RAX29 UDP Port Forwarding
I've recently had to upgrade our router. I have a Nighthawk RAX29 with the latest 1.0.9.92_1 firmware. I have an Unraid server configured with a WireGuard VPN. This worked flawlessly on our old r...
jagoose
Feb 10, 2023Aspirant
I'm running V1.0.9.92_1 on RAX30 and encountered the same problem. No matter I chose TCP/UDP or UDP in custom services, the setting always reverted back to TCP!!!
- Taddeusz2002Feb 10, 2023AspirantI had to switch browsers. Safari on macOS was not working. I can’t remember which browser ended up working for me so just try different browsers.
- michaelkenwardFeb 10, 2023Guru - Experienced User
Taddeusz2002 wrote:
I had to switch browsers. Safari on macOS was not working.Many Netgear manuals say things like:
"This recovery process is supported in Internet Explorer, Firefox, and Chrome browsers, but not in the Safari browser."
Not sure what else it affects.
- jagooseFeb 10, 2023Aspirant
Thanks for your useful advices. I finally set it using Edge on Windows after trying all different browsers on MacOS, iOS and Android.
