bardiferously
Jun 25, 2024Aspirant
RAX29 WiFi 6 Router not connecting at WiFi 6 with my laptop
Nighthawk AX2400 WiFi 6 Router (RAX29) connects with my laptop at WiFi 5 (ac). How do I have it connect with WiFi 6 (ax)? My laptop's card is the Intel Wi-Fi 6 AX201. Looking for the wisdom of ...
bardiferously
Jan 21, 2025Aspirant
Back to my original question: Why does my Guest 5GHz network use the AX protocol while my Primary network (using the "Smart Connect" option) at 5Ghz use the AC protocol?
My Equipment consists of:
- CM1100 Modem
- AX2400 WiFi Router (RAX29)
- Intel Wi-Fi 6 AX201 card inside my Windows 11 laptop
- ISP is Xfinity
- All hardware has most up-to-date drivers & firmware; Windows 11 24H2 is also up to date
- Both Netgear Modem & Router installed with basic, factory settings
- the RAX29 was set up using the Nighthawk App and the option to have Smart Connect enabled on the Primary network
- FWIW, the default gateway on my home network is 10.0.0.1, not something I selected but was "there" when I plugged in the Modem and it was activated by Xfinity
And this is for NETGEAR - WHY WON'T MY RAX29 ROUTER POPULATE IN THE ASSOCIATED PRODUCTS field above???
Jan 21, 2025Guru - Experienced User
Do any other devices have issues? Or just the one?
Have you checked?
