donl1155's avatar
Apr 27, 2022
RAX30 2.4 OR 5G
I want to use some 'smart plugs' mfgd by YoLink to control house lights.  They only support networks using 2.4.  When I try to link the YoLink device to the network, it is denied.  No doubt the route...
  • plemans's avatar
    Apr 28, 2022
    You can try re-enabling it. It might work/connect. If it doesn't, just disable it. Or use an old wireless N router for those devices (in access point mode)
    Basically means poor coding on the yolink part.
    but at least you've figured out what needs to be done.
    Great work.
    I'd mark the solution as solved since you know whats causing it and how to fix it.
