donl1155
Apr 27, 2022Guide
RAX30 2.4 OR 5G
I want to use some 'smart plugs' mfgd by YoLink to control house lights. They only support networks using 2.4. When I try to link the YoLink device to the network, it is denied. No doubt the route...
- Apr 28, 2022
You can try re-enabling it. It might work/connect. If it doesn't, just disable it. Or use an old wireless N router for those devices (in access point mode)
Basically means poor coding on the yolink part.
but at least you've figured out what needs to be done.
Great work.
I'd mark the solution as solved since you know whats causing it and how to fix it.
donl1155
Apr 27, 2022Guide
Thanks for the tips.
I have tried connecting both with/without Smart Connect activated. Neither will connect. As for the phone, I have an iPhone. How do I make sure it is on 2.4 during connection? Can't see an option in the iPhone to do that.
Apr 27, 2022Guru - Experienced User
With smart connect disabled, simply name the 5ghz something different from the 2.4ghz. That'll allow you to know which to connect to.
also make sure to disable icloud relay and random ip/mac on the iphone. I've seen those cause issues lately
- donl1155Apr 27, 2022Guide
Thanks. I have disabled smart connect and the 2 bands do have different names. See screenshot from Nighthawk. icloud relay and random ip are disabled. The app from YoLink doesn't allow me to pick a band. When I get to the screen where it wants me to log in, it says 5-GHz band is not supported. No option to change to the 2.4 band. It then simply searches and comes up empty.
- plemansApr 28, 2022Guru - Experienced User
Make sure your phone is connected to the 2.4ghz during setup. If the app is saying "5ghz not supported" its picking up the phone is connected to 5ghz.
- donl1155Apr 28, 2022Guide
Set up a guest network with 2.4 only. Tried connecting the hub and it still showed the 5G message. I tried to connect/authenticate anyway but it would not. Timed out. Tried again. Same thing.
