donl1155
Apr 27, 2022Guide
RAX30 2.4 OR 5G
I want to use some 'smart plugs' mfgd by YoLink to control house lights. They only support networks using 2.4. When I try to link the YoLink device to the network, it is denied. No doubt the route...
- Apr 28, 2022
You can try re-enabling it. It might work/connect. If it doesn't, just disable it. Or use an old wireless N router for those devices (in access point mode)
Basically means poor coding on the yolink part.
but at least you've figured out what needs to be done.
Great work.
I'd mark the solution as solved since you know whats causing it and how to fix it.
donl1155
Apr 28, 2022Guide
I went into the router and disabled AX (whatever that is, I have no clue). I tried to connect and lo and behold it worked! Looks like that did the trick!! Thanks.
Now my question is, do I go back in and enable AX and will YoLink still work?
Apr 28, 2022Guru - Experienced User
Great work.
