Rod_Horning
Jun 05, 2024Tutor
RAX30 403 Forbidden
Firmware Version V1.0.10.94_3 I replaced a LINKSYS router with the Nighthawk RAC30. I have several systems connected to the Nighthawk: Windows 10, Windows 11, 2 Linux systems, Android. They seem...
microchip8
Jun 05, 2024Master
That's a server problem, not router. 403 is a permission issue somewhere in your htdocs or configuration. The server is reachable over the net, just reports a 403
- Rod_HorningJun 05, 2024Tutor
That is what I thought though I have not found the issue.
The question is why did it work with the previous LINKSYS router? That only thing that changed was the router.
Additional information
The router is sending its internal, self-signed, SSL certificate instead of the web site certificate.- microchip8Jun 06, 2024MasterHave you tried placing the IP of the server in the DMZ on the router?
