Rod_Horning
Jun 05, 2024Tutor
RAX30 403 Forbidden
Firmware Version V1.0.10.94_3 I replaced a LINKSYS router with the Nighthawk RAC30. I have several systems connected to the Nighthawk: Windows 10, Windows 11, 2 Linux systems, Android. They seem...
microchip8
Jun 05, 2024Master
That's a server problem, not router. 403 is a permission issue somewhere in your htdocs or configuration. The server is reachable over the net, just reports a 403
Rod_Horning
Jun 05, 2024Tutor
That is what I thought though I have not found the issue.
The question is why did it work with the previous LINKSYS router? That only thing that changed was the router.
- Rod_HorningJun 05, 2024Tutor
Additional information
The router is sending its internal, self-signed, SSL certificate instead of the web site certificate.- microchip8Jun 06, 2024MasterHave you tried placing the IP of the server in the DMZ on the router?
- Rod_HorningJun 06, 2024Tutor
Thank you for your response.
Yes, I gave that a try. No change.
