Darron5FollowerApr 30, 2023RAX30 5.0 GHz is not working.I can use the 2.4 GHz but the 5.0 does not even show up anymore.
1 ReplyReplies sorted by OldestplemansGuru - Experienced UserApr 30, 2023Are you using smart connect? Smart connect combines the 2.4ghz and the 5ghz so it only shows as one ssid.
