Darkricra
Jul 08, 2023Aspirant
Rax30 amber light or no light on internet led
I’m not extremely computer savvy so I need help. My rax30 keeps intermittently showing the internet led light as amber or off. Everything is connected and seems ok for a while then I lose internet ...
Darkricra
The modem I have is an Arris surfboard sb6141. It’s just a modem, not a router.
Router firmware version v1.0.10.94_3
I just found out my internet provider is working on a “node” in the area. I’ve been having issues off and on for a while though, so not sure that will be the fix i need.
michaelkenward
Jul 09, 2023Guru - Experienced User
Good. That rules out a lot of possible problems.
Does the modem have LEDs that tell you anything useful? If that isn't connected. then your router can't either.
Do the router's logs have any useful clues?
There has been a "Hotfix" since then.
RAX30 Firmware Version 1.0.11.96 - Hot Fix | Answer | NETGEAR Support
No harm in trying, but I wouldn't expect that to fix this sort of problem.
