SunshineSail
Oct 08, 2025Tutor
RAX30 Bridge Mode
I live in an apartment complex which global wifi across the building. I'd like to setup a local network using the RAX30 in bridge mode. I assumed the RAX30 could connect to the building WIFI and th...
- Oct 13, 2025
Good call. My coat closet has an access panel for the building's fiber to eth switch. I tapped into that and am now running the RAX30 in its normal router mode. Thanks for the suggestion!
CrimpOn
Oct 08, 2025Guru - Experienced User
Yes, a WiFi Extender (from anyone) would connect to the apartment WiFi system and create a separate WiFi network.
The RAX30... will not work.
Does the apartment limit the number of devices which can be connected to the central WiFi network? In other words, "why do you want to do this in the first place?"
