SunshineSail
Oct 08, 2025Tutor
RAX30 Bridge Mode
I live in an apartment complex which global wifi across the building. I'd like to setup a local network using the RAX30 in bridge mode. I assumed the RAX30 could connect to the building WIFI and th...
- Oct 13, 2025
Good call. My coat closet has an access panel for the building's fiber to eth switch. I tapped into that and am now running the RAX30 in its normal router mode. Thanks for the suggestion!
Oct 09, 2025Guru - Experienced User
You might even just check with them (apartment managers who setup the wifi, not the front desk people) to see if one of the access panels in the apartment has ethernet that you can connect your own AP to. Many have this option. It'd give you faster speeds as setting it up with an extender in the middle will decrease your speeds and increase you latency.
