Retired_Member
Jul 23, 2022RAX30 Corrupted by Quad9 Setup Attempt
I made the mistake of trying to set up my router to use Quad9. It took the ipv4 IP settings, but said the ipv6 addresses were invalid. I should have stopped at that point, but I didn't. Now I ca...
Retired_Member
Jul 24, 2022The Netgear app on my iPhone doesn't find the router.
It appears that the router is using Quad9, and that Quad9 either because of its strict privacy and/or because its database of translations of names to IP addresses is very limited.
Jul 24, 2022Guru - Experienced User
This wouldn't be a Quad 9 issue.
Can you access the routers web page at 192.168.1.1 with a wired PC and web browser?
Where did you input quad 9 configuration? Under the DNS settings? I use Quad9 all the time here.
For Iphone issues and Nighthawk app issues, make sure that WiFi Private Address is disabled and Local Network for the NH app is Enabled.
You might factory reset the router and setup from scratch with a wired PC and web browser first.
