Legit_File
Jul 13, 2023Aspirant
RAX30 Drops Connection
So I've done the run around with my ISP, got a new modem, and they swear it's not them. "The modem never loses signal", so that got me over to netgear support. Using the RAX30, I'd get random "connec...
michaelkenward
Jul 13, 2023Guru - Experienced User
Legit_File wrote:
Firmware Version V1.0.10.94_3
It probably won't make any difference to your issue, but there is newer "hotfix" firmware for your router:
RAX30 Firmware Version 1.0.11.96 - Hot Fix | Answer | NETGEAR Support
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
Legit_File
I remembered after posting that the hot fix didn't show up when you click update, so I manually upgraded it, still causing issues.
