Rod_Horning
Jun 12, 2024Tutor
RAX30 extern antenna
Does anyone have experience with or recommendation for an external high-gain antenna? At RV parks I often find the WiFi signal weak due to distance from the "tower". I'm wondering is a high gain ...
- Jun 12, 2024
The RAX30 is a router only device. it doesn't have any modem capability so its not connecting to any "tower".
The problem with most rv's (not all) is that they're made with metal exteriors. Which makes them an excellent Faraday cage (blocks wifi). It blocks wifi to an amazing extent.
Are you trying to connect to the RV parks wifi or cellular? Because each will take a different strategy.
Jun 12, 2024Guru - Experienced User
Rod_Horning
Jun 13, 2024Tutor
By "tower" I meant the WiFi antenna(s) in the RV Park.
Yes, I understand the Faraday cage.
And I must have been half asleep when I posted this as of course the router is NOT a modem.
My apologies.
