Skymike
May 23, 2023Aspirant
RAX30 How to increase UDP timeout for Voip
I have recently installed RAX30 AX2400 for general use and Voip. The Voip by Gama is not working correctly and the software supplier advises that the UDP timeout needs to be increased to 300 secs. ...
- May 23, 2023Unless you gain access to the command line of the RAX30 using telnet & co, it is not possible to change UDP or TCP timeouts.
May 23, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Try using the routers DMZ for the VoIP device.
microchip8
May 23, 2023Master
