Skymike
May 23, 2023Aspirant
RAX30 How to increase UDP timeout for Voip
I have recently installed RAX30 AX2400 for general use and Voip. The Voip by Gama is not working correctly and the software supplier advises that the UDP timeout needs to be increased to 300 secs. ...
- May 23, 2023Unless you gain access to the command line of the RAX30 using telnet & co, it is not possible to change UDP or TCP timeouts.
May 23, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Try using the routers DMZ for the VoIP device.
Skymike
Firmware is V1.0.10.94_3. Modem is UK Openreach FTTP ONT, standard UK domestic. VoIP via DECT handsets linked to CISCO ATA192 fed from Router via GS105 switches, cat5e and cat6 cables.
Problem is Game say increase UDP timeout and microchip8 has just messages it can only be dome access to the command line via telnet and that is way outside my payscale. back to the drawing board, maybe.
- FURRYe38May 23, 2023Guru - Experienced User
Give the DMZ of the router a try.
- SkymikeMay 23, 2023Aspirant
I appreciate the thought but (a) I am limited by the VoIP software provider; (b) I am not competent to fiddle in the black box ; and (c) I am running a small publishing business here and I am not keen on the potential increased risk in using a DMZ server. Thanks for taking the time.
DMZ would only be configured on the NG router. Just as a test to see if it works.
Risk is low for VoIP devices in the DMZ. Not much to hack there.
